File Request HP 450 G3 machine is not in committed state
webspinner
Registered
reputation_scoree
MotherBoard Model
827025-001
Laptop Model
450 G3
Hello,
I replaced a motherboard in a HP 450 G3 laptop but it when it boots up I get the following error
WARNING!! Machine is not in committed state!
System is booting in Manufacturing Program Mode.....
Is anyone able to help or provide advise?
Mike
Salimeh Bolboli
Staff member
Admin
Registered
Hello. Please check this article
webspinner
Registered
reputation_scoree
I did try that but I receive the following error:
VPro configuration not supported (read)Bad variable specification
Errorlevel =
Syntax error
exit with errors!
end of execution
Maybe I dont have the correct AMTBrand tool? I used Rufus to create a FreeDOS bootable USB
webspinner
Registered
reputation_scoree
Which level? would bronze be enough?
Yes I am a repairman but never edit the bios file, simply use the file provided by manufacture.
webspinner
Registered
reputation_scoree
Here is the bios file, I used the HP BIOS tool to generate this backup file. Will it be sufficient?
  • N78_0151.bin
webspinner
Registered
reputation_scoree
I don't think I am able to get the original file, as in from HP? so are you meaning download the file directly from the bios chip?
webspinner
Registered
reputation_scoree
incorrect how so?
I used a CH341a programmer and AsProgrammer to pull the bios file from the chip. Was it something I did wrong or is the BIOS incorrect?
webspinner
Registered
reputation_scoree
That is interesting, when I try and use CH341A programmer I get the following info
manufacture: other
memory name: unknown
memory size: unknown
I tried both the old motherboard and the new one with the same result
When I tried AsProgrammer it took several tries before it detected the BIOS chip and then it finally did and that is when I saved the file, this file is what I sent.
I have tried again and attached a new file plus a screen capture of what it shows in the program.
  • HP 450 G3.bin
Vahab Hemmati
Support Team
Staff member
Admin
Registered
manufacture: other
  • 450 G3 New.zip
webspinner
Registered
reputation_scoree
I tried the file Vahab Hemmati sent to me Wednesday of last week, that was the last one I have received so far
webspinner
Registered
reputation_scoree
I flashed it but now it doesn't post, caps lock flashes every 4-5 seconds for a bit then stops, after which the fan spins up. Black screen, wifi, power light, hard drive light and mute are on solid
Users who has read this topic
